Nope, no pickup unitDid you check your ignition for a pickup unit? Do or don't you have it on there?
Removed the cylinder (A5) and piston (no window version), and installed an Airsal 50cc kit.
No questions are stupidMaybe a stupid question, but did you put your piston in the right way? I mean with the window towards the inlet valve. I find it strange that your "old" setup works with a 54 jet and enlarged outletport of the exhaust and now with a Airsal 50cc not. Did you change every seal between cylinder and engineblock and head? Did you turn every nut crosswise and with the right amount of torque? Normally if you can say yes to all questions i would prefer to change the sealrings from your crankshaft.
I don't know how much force it needs to push the kickstart down (as you say with 5 kg). Only i can tell by doing it by hand and i can push it down you need to replace them. When in doubt just replace them in precaution. So you elimintate one cause of why the engine doesn't run. Still i think it's an airleak.
Nope, the original cylinder exhaust port is not aligned to the ground. Its an angle.. higher towards the front wheel. Comparing to a friends Quadro 2003 wich also has A52 block but this port is exactly horizontal, same as the Airsal on my moped.And does the first part before the curve stay perpendicular to the ground when you only mount this to your cilinder? If yes, than it's the right, if no maybe the exhaust port is angled (like an A55 cylinder) and you need to , or bend this frontpipe, or buy an other exhaust that will fit proparly.
Could you post a picture when this frontpipe is mounted to the cilinder? And maybe a photo of the rest of the exhaust and the mounting at the rear?
So now you have this Airsal cylinder wich has the exhaust port aligned to the ground or not? If your exhaust port is still angled (toward front) you need A55 exhaust.Nope, the original cylinder exhaust port is not aligned to the ground. Its an angle.. higher towards the front wheel. Comparing to a friends Quadro 2003 wich also has A52 block but this port is exactly horizontal, same as the Airsal on my moped.
So I will be ordering an A35 exhaust
