gros problème
1 bericht • Pagina 1 van 1
frede85
Berichtdoor frede85 » 06 jun 2020 22:44
hello everyone
I use google translation since I speak French so excuse me if I am not very clear
so I have a Tomos quadro that I put back in eta there was no ignition and the E-start system does not work I therefore carried out the following repairs new starter relay, magnetic flywheel, ignition stator , E-start engine and finally new ignition coil new spark plugs and new battery.
faith all the rise I wanted to test the E-starte so I press the rear brake the brake light comes on press the start buttons and the E-start engine has turned (in a vacuum) and since more nothing more stop lights more nothing there is only the flasher which works the only part which I have left to change are the cable buttocks and the voltage regulator do you think that the problem comes from there?
Gebruikers op dit forum: Majestic-12 [Bot] en 10 gasten
