OMFG! That's a bunch of bullsh*t! A HPI ignition doesn't EVEN give a performance boost, it only gives a better throttle reaction, and it's possible to run the engine at higher revs. Nothing more!Your acceleration will be mutch better ...mutch better gas reaction...but beware for the power you will get,..it might damage your airsal cilinder kit...
you muts need an good spark plug ,...check your clutch weekly...if you use your moped every day its not smart to install this ignition on your tomos...could you explain your second question , than I will try to give the right answer,...
You? Giving a right answer?Your acceleration will be mutch better ...mutch better gas reaction...but beware for the power you will get,..it might damage your airsal cilinder kit...
Gebruikers op dit forum: Baidu [Spider] en 3 gasten
