das anybody have or had a problem with a crankshaft if mounted a 70 ccm kit, sport exhaust and bigger carb ???........and if you had a problem how did you fix it???
thanks for answers
sitt
hellracer is planning to fit a 70cc Italikit Honda NSR LC cilinder,
iand maybe there is an other crank fitted in the export models but It also might be the diffirence in the cilinders we use![]()
Wel I asked it because I didn't know IF you got the point.in my country that last question would be understud like a threat or an insult and not like a smart observation and advice of the moderator.
But perhaps in your country means somthing else ???
