Pagina 4 van 5
Re: Tomos BT90 project
Geplaatst: 09 mei 2011 12:05
door Marv
We only have the AT, ATX, and NTX versions over here.
Geplaatst: 09 mei 2011 20:37
door 2pac
We dont have BT here the only motorcycle tomos in the netherlands was the tomos ts50 with top speed of 85/kmh
Ive buy it on something like ebay in your country
Geplaatst: 11 mei 2011 23:43
door jordy1993t
Wauw very nice i look it very much! How is the project going right now?
Geplaatst: 13 mei 2011 02:29
door pomartin
im still waiting for crankshaft...
Geplaatst: 29 mei 2011 16:08
door pomartin
Geplaatst: 29 mei 2011 20:56
door Alex..
looks great Pomartin, id like to see it when its finished,
ps; Could you inform about Ales, i havent heard from him since friday when he would sent me pictures, he was supposed to send all the parts tomorrow but i havent heard anything yet
Geplaatst: 31 mei 2011 22:27
door pomartin
Geplaatst: 31 mei 2011 22:31
door Alex..
looks real nice again Pomartin,
what cylinderhead do you use?
and ales has some problems with internet he said, so he responds very late or something,
so i guess its fine
Geplaatst: 31 mei 2011 22:41
door pomartin
cylinderhead is from Tomos CTX. it is good, becouse it has almost excellent squish, but i still need to make some measurements
Geplaatst: 01 jun 2011 19:40
door pomartin
cap for intake was made... still need to drill holes and polish it.
also found material for flange- inside fi 29
Geplaatst: 01 jun 2011 20:53
door 2pac
realy nice
I have some question
I wanna give my bt engine more compression
i have a Bt cilinder High pressure cilinderhead and another exhaust 18mm intake and dellorthe 19mm carburater
Ive heard that there are 2 holes in the carter where your crankshaft is
if i fill them it have more compression
Can you confirm that?
And is there any limiter in the exhaust i have a NTX exhaust something like on a CTX
II hope you will help me
Geplaatst: 01 jun 2011 21:56
door pomartin
you can fill those holes in crankshaft with cork... it have some effect, and if something happens, cork is soft and it cannot do any dammage
it wont lift your compression, but performances will be better.
the only thing you can do for better compression is lowering cilinderhead
ctx exhaust has limiter. inside is a longer tube, wich disable resonant effect... and it have metal grid allover the exhaust
Geplaatst: 02 jun 2011 10:24
door 2pac
Oke thankx
No not the holes in the crankshaft
but in the room where the cranckshaft is are 2 holes that are 5mm ore something they say to my
Geplaatst: 02 jun 2011 14:32
door pomartin
yes... you can fill them too.. make a thread and put in a screw. i recommend that you use metal glue too
Geplaatst: 02 jun 2011 17:41
door 2pac
Oke realy thanx for you answer
Geplaatst: 02 jun 2011 22:02
door pomartin
no problem
Geplaatst: 02 jun 2011 22:19
door 2pac
Now i have some work
Did it make alot of difference to fill that holes?
Geplaatst: 03 jun 2011 00:00
door pomartin
it depends on all other tunning... but it is positive difference for shore
Geplaatst: 03 jun 2011 00:01
door Alex..
and Pomartin, do you know which piston you need for AT/BT/NTX Cylinder ?
Geplaatst: 03 jun 2011 00:37
door pomartin
well it depends on what fi of cilinder do you have...
if you want to know which mark... there are a lots of marks of pistons for tomos... i use vertex or meteor, könig is also very good
, i strongly reccomend that you do NOT use sukoki... it is very bad quality and toleranced for watercooled engines...
