hello
Geplaatst: 15 feb 2008 19:31
door slomoped.net
hello my dutch friends!
i am from the forum http://www.slomoped.net
i come from slovenia and i'm inviting you to join our forum so we can talk about our love, Tomos.
we will soon setup a topic where people that are not Slovenian may have their space and can talk in english or their own tung...
i hope that this topic is in the proper place if not put it in a proper place.
cheers 8) 8) 8)
Re: hello
Geplaatst: 15 feb 2008 20:24
door tomos4ever
i have visit your website another thime ago
but when i visit the website i can not read everything it is all writed in slovenia
but is wil register on your website because tou are about TOMOS O+
Re: hello
Geplaatst: 16 feb 2008 11:08
door slomoped.net
good good.
i will post here when we will get the english section running 8)
Re: hello
Geplaatst: 16 feb 2008 12:14
door tomos4ever
thanx than i can register my self at your forum
greets
Re: hello
Geplaatst: 16 feb 2008 15:23
door DRAGON88
slomopeds :P some tomos are fast 8)
Re: hello
Geplaatst: 16 feb 2008 15:34
door PimW
SLOvenian MOPEDS
doh :roll:
Re: hello
Geplaatst: 16 feb 2008 15:45
door poekelen
spam topic :')
Re: hello
Geplaatst: 16 feb 2008 23:26
door slomoped.net
good friends i am posting this here because i don't know where to put it so if a moderator can place this in a proper spot.
PERFECT BROWN CROWN
The crown of this piston shows an ideal carbon pattern. The transfer ports of this two-stroke engine are flowing equally and the colour of the carbon pattern is chocolate brown. That indicates that this engine's carb is jetted correctly.
BLACK SPOT HOT
The underside of this piston has a black spot. The black spot is a carbon deposit that resulted from pre-mix oil burning on to the piston because the piston's crown was too hot. The main reasons for this problem are overheating due to too lean carb jetting or coolant system failure.
ASH TRASH
This piston crown has an ash color, which shows that the engine has run hot. The ash color is actually piston material that has started to flash (melt) and turned to tiny flakes. If this engine was run any longer, it probably would,ve developed a hot spot and hole near the exhaust side and failed. The main causes of this problem are too lean carb jetting, too hot spark plug range, too far advanced ignition timing, too much compression for the fuel's octane, or a general overheating problem.
SMASHED DEBRIS
This piston crown has been damaged because debris entered the combustion chamber and was crushed between the piston and the cylinder head. This engine had a corresponding damage pattern on the head's squish band. The common causes of this problem are broken needle bearings from the small or big end bearings of the connecting rod, broken ring ends, or a dislodged ring centering pin. When A problem like this occurs, its important to locate where the debris originated. Also the crankcases must be flushed out to remove any left over debris that could cause the same damage again. If the debris originated from the big end of the connecting rod, then the crankshaft should be replaced along with the main bearings and seals.
CHIPPED CROWN DROWNED
This piston crown chipped at the top ring groove because of a head gasket leak. The coolant is drawn into the combustion chamber on the down-stroke of the piston. When the coolant hits the piston crown it makes the aluminium brittle and it eventually cracks. In extreme cases the head gasket leak can cause erosion at the top edge of the cylinder and the corresponding area of the head. Minor leaks of the gasket or o-ring appear as black spots across the gasket surface. An engine that suffers from coolant being pressurized and forced out of the radiator cap's vent tube, is a strong indication of a head gasket leak. In most cases the top of the cylinder and the face of the cylinder head must be resurfaced when a leak occurs. Most mx bikes have head stays mounting the head to the frame. Over time the head can become warped near the head stay mounting tab, because of the forces transferred through the frame from the top shock mount. It's important to check for warpage of the head every time you rebuild the top end.
SHATTERED SKIRT
The skirts of this piston shattered because the piston to cylinder clearance was too great. When the piston is allowed to rattle in the cylinder bore, it develops stress cracks and eventually shatters.
SNAPPED ROD
The connecting rod of this engine snapped in half because the clearance between the rod and the thrust washers of the big end was too great. When the big end bearing wears out, the radial deflection of the rod becomes excessive and the rod suffers from torsion vibration. This leads to connecting rod breakage and catastrophic engine damage. The big end clearance should be checked every time you rebuild the top end. To check the side clearance of the connecting rod, insert a feeler gauge between the rod and a thrust washer. Check the maximum wear limits in your engine's factory service manual.
FOUR-CORNER SEIZURE
This piston has vertical seizure marks at four equally spaced points around the circumference. A four-corner seizure is caused when the piston expands faster than the cylinder and the clearance between the piston and cylinder is reduced. Another common problem of this type is a single point seizure on the center of the exhaust side of the piston. However this occurs only on cylinders with bridged exhaust ports. The main causes for this problem are too quick warm-up, too lean carb jetting (main jet), or too hot of a spark plug range.
MULTI-POINT SEIZURE
This piston has many vertical seizure marks around the circumference. This cylinder was bored to a diameter that was too small for the piston. As soon as the engine started and the piston started its thermal expansion, the piston pressed up against the cylinder walls and seized. The optimum piston to cylinder wall clearances for different types of cylinders vary greatly. For example a 50cc composite plated cylinder can use a piston to cylinder wall clearance of .0015 inches, whereas a 1200cc steel-sleeved cylinder snowmobile set-up for grass drags will need between .0055 to .0075 inches. For the best recommendation on the optimum piston to cylinder clearance for your engine, look to the specs that come packaged with the piston or consult your factory service manual.
INTAKE SIDE SEIZURE
This piston was seized on the intake side. This is very uncommon and is caused by only one thing, loss of lubrication. There are three possible causes for loss of lubrication, no pre-mix oil, separation of the fuel and pre-mix oil in the fuel tank, water passed through the air-filter and washed the oil film off the piston skirt.
COMPOSITE FLAKING
Most two-stroke cylinders used on motorcycles and snowmobiles, have composite plated cylinders. The composite material is made of tiny silicon carbide particles. The electro-plating process enables the silicon carbide particles to bond to the cylinder wall. The particles are very hard and sharp, they don't bond to the ports so the manufacturer or reconditioning specialist must thoroughly clean the cylinder. Sometimes the silicon carbide "flashing" breaks loose from the ports and becomes wedged between the cylinder and the piston. This causes tiny vertical scratches in the piston. This problem isn't necessarily dangerous and doesn't cause catastrophic piston failure, but it should be addressed by thoroughly flushing the cylinder and ball-honing the bore to redefine the cross-hatching marks. Normally you will need to replace the piston kit because the scratches will reduce the piston's diameter beyond the wear spec.
BURNT-OUT BLOW-HOLE
This piston was overheated so badly that a hole melted through the crown and collapsed the ring grooves on the exhaust side. Normally the piston temperature is higher on the exhaust side so catastrophic problems will appear there first. There are several reasons for a failure like this, here are the most common; air-leak at the magneto side crankshaft seal, too lean carb jetting, too far advanced ignition timing or faulty igniter box, too hot of a spark plug range, too high of a compression ratio, too low octane fuel.
BLOW-BY
This piston didn't fail in operation but it does show the most common problem, blow-by. The rings were worn past the maximum ring end gap spec, allowing combustion pressure to seep past the rings and down the piston skirt causing a distinct carbon pattern. Its possible that the cylinder walls cross-hatched honing pattern is partly to blame. If the cylinder walls are glazed or worn too far, even new rings won't seal properly to prevent a blow-by problem. Flex-Hones is a product available at most auto parts stores. They can be used to remove oil glazing and restore cross-hatch honing marks that enable the rings to wear to the cylinder and form a good seal. If you purchase a Flex-Hone for your cylinder, the proper grit is 240 and the size should be 10% smaller than the bore diameter.
the link:
http://www.smellofdeath.com/lloydy/pist ... _guide.htm
