Airsal a35 cylinder head gasket?
Geplaatst: 29 sep 2010 07:02
door granturismo
Hello,
Sry I dont speak dutch but this forum is great :-)
Anyways. I have a flexer eu25 2006. Airsal 50cc kit and a DMP cylinder head. Question is: Do I need the cylinder head gasket wich is 1.0mm thick?
Thanks
EDIT: Compression is 9Kg.. good or can be better?
Re: Airsal a35 cylinder head gasket?
Geplaatst: 29 sep 2010 08:18
door 2pac
Yes you need a gasket :P
Do you have pictures of your moped
Geplaatst: 29 sep 2010 10:49
door Joren
You can try it whitout the gasket, but check if the piston is not hitting the cylinder head.
whitout gasket will result in more compression = more power =)
Geplaatst: 29 sep 2010 11:59
door Fakemon
But if the piston is hitting the head it doesn't have much use, hehe.
Nice to see some foreigners around here though, at least that shows how great Tomos is. :evil:
As people say: Try it. If it's possible to use it without the gasket it's okay. But if it starts ticking against the head it's a big NO.
Geplaatst: 29 sep 2010 14:53
door granturismo
I thought Quadro came without head gasket from factory? Or maybe it is thinner?
This is my moped. It's not finished yet. But see the dutch inspired orange springs, and later there will be "TOMOS" in orange painted on the sides :P
Geplaatst: 29 sep 2010 14:59
door granturismo
I have made a thinner copy (got help at a factory), wich is 0.5mm instead of 1.0mm. Both in aluminium. Will try that first :) Or somehow measure the distance between the piston and head..... :)
Geplaatst: 29 sep 2010 15:06
door granturismo
Haha well that's not so good i've heard :wink: .
No idea if the DMP head has same measurement as eu45/quadro. I got 9Kg of compression now, instead of 5 before btw.
I'm not that far away... I'm swedish, but tomos is cool :P
Geplaatst: 29 sep 2010 16:06
door Fakemon
It's kinda far away.. Hehe. But still, if everyone knew Tomos was great.. That'd be a better world wouldn't it?
Anyhow, if you just put the cylinderhead on and give it a light kick, and it ticks; you know not to use it without gasket. But if it just works it's okay. Tell us what you did, that's always handy to know. :p
Do you have a lot of trouble getting parts for your Tomos there btw?
Geplaatst: 29 sep 2010 18:37
door granturismo
Takes a while on a moped I guess :) Yes, I've actually emailed Tomos to do some marketing here and bring more models. Right now only Flexer EU25 is sold :(
Didn't work.. the piston hitted the sparkplug. So I went back to the 1mm gasket. I think I need to upjet also... higher comp=upjet?
Original parts for all Tomos ever sold here is easy obtained. But worse on tuning parts...
Geplaatst: 29 sep 2010 18:42
door Fakemon
I see.. Must suck that you're having a hard time to get all the tuning parts. I mean I have, in a 10 kilometer radius, about 5 differnet shops for it.
And what exactly do you mean with the higher comp?
I think everything should be working properly with the 1mm gasket.
Geplaatst: 29 sep 2010 19:34
door granturismo
Tomos is a small brand here, so most shops don't have tuning parts for it :(
Before I had the original eu25 cylinder head and 5 kg compression. Now with DMP head I got 9 kg.
It was running rich before.. but guessing it's running lean now instead
Geplaatst: 29 sep 2010 19:36
door Fakemon
Depends. How does your spark plug look by now?
Is it black: Running too rich.
Is it white: Running too low.
Is it coffee with milk: ( so brown-ish ) then it's okay.
Geplaatst: 30 sep 2010 16:40
door granturismo
I haven't tried it yet. Will a plug chop work with a used spark plug or do I need a new one? And does it need to cool down to get the correct color?
Geplaatst: 30 sep 2010 21:26
door granturismo
Crap! The angle from the Airsal exhaust port is very different. Had a gap at the back, where the pipe is connected :(
Geplaatst: 30 sep 2010 21:51
door JesseJeremy
you mean diffrent from the gasket ?
Geplaatst: 30 sep 2010 22:39
door shadowranger
Nope, different exhaust port angle, like between A5 and A55 cylinder. See his other topic. Probably an Airsal for Puch or so.
