Pagina 1 van 5
Tomos BT90 project
Geplaatst: 04 mar 2011 20:00
door pomartin
Hello :D
Greetings from Slovenia :D
First i mus say... nice forum you got here :)
Let me introduce you my project :wink:
It all started when i bought tomos BT 50N and then start restoring it :
AfbeeldingAfbeeldingAfbeeldingAfbeeldingAfbeeldingAfbeelding
now it is waiting
than i started engine tunning
at first... two boosts
and than... 4 boosts :D
exhaust is 190° transfer 130°
i also made a reed-valve take-in
step 1- welding
Afbeelding Afbeelding
step 2- making hole :D
i already enlarged the hole, so the reed valve have enought space for opening
Afbeelding AfbeeldingAfbeelding
i still have to polish it :P
then i bought bigger carburator- dellorto PHBH28
then one day, i was bored, and i modified serial MF3
and i allready made a plan for custom exhaust :D
than there was another boring day and i decided to make a plan for 6 speed gearbox
.. but 6 is too few... so i decided to make it seven :D
but there was some problems becouse of one screw hole, and instead of replacing the whole screw location, i desided to make 6 speed gearbox, but with gears from 2 to 7 :D
Afbeelding Afbeelding Afbeelding
6th and 7th gear from the secondary transmission
i also had to modify "frame" of engine to fit it in. the distance from sprocket and alluminium is 0,4 mm :mrgreen:
than i had to amplify clutch drum
the top ring is stil under construction
than i ordered better bearings for crankshaft
FAG NJ 203 ECP :)
i have ordered better big-end bearing -silver cage and more needles- for connecting rod too. But i didnt get it yet, becouse tey do not sell it in our country. So i have ordered it from your country- from EMOT.nl GOD BLESS NETHERLANDS O+
The crankshaft still needs to be build:
there is enought material for 4 excellent and one bad crankshaft
and a difference between tomos 80-90cc original connecting rod- the gray one and the one which is made in Serbia this days.
a few things have to be done, but i must wait to get all the bearings.
18 horsepowers is expected- by calculations :P
i spend 1100€till now, and next week i will give the cylinder to renewal-- new nikasil--- +100€
comments and critics welcome :D
Re: Tomos BT90 project
Geplaatst: 04 mar 2011 20:07
door MichielWolthaus
Hmm, I've seen this Tomos already, on mopedist.si
Geplaatst: 04 mar 2011 20:09
door pomartin
yes :D
i read in your topic that you have forum too, so i decided to pay a visit ;)
allright, atleast you've got an nice Tomos!
or actually you've only got nice parts :wink:
Geplaatst: 04 mar 2011 20:12
door pomartin
hehe :D
soon it will be tomos ;)
Geplaatst: 04 mar 2011 20:13
door 2pac
Oehh like like like
The bt cilinders are fast :wink:
nice ideas
I have a Tomos NTX And a bt 50 cilinder And 17,5 mm carburator
Im gone buy a 21 mm carburater and 21 mm intake
Maby you have a 21 mm bing and 21 mm intake
Here below you can see my moped
door pomartin
i do not have bt cylinder. i have e90 :D
that is 90ccm :D
and i allready saw your mopeds, and i like them :D a lot :D
Geplaatst: 04 mar 2011 20:20
door 2pac
Ha thnx on mopedist .si
I'm painting my moped when it's about 15 degrees outside.
I I have no idea which kind of color i'd paint it, do you have any suggestions?
Geplaatst: 04 mar 2011 20:21
door 2pac
Geplaatst: 04 mar 2011 20:22
door pomartin
metal-blue :D
for my opinion this is the best color for bt/atx/ntx models :wink:
hehe nice commercial :P
Geplaatst: 04 mar 2011 20:24
door 2pac
haha oke bleu metallic
there are more commercials
Geplaatst: 04 mar 2011 21:23
door drestar
Nice :D
Geplaatst: 04 mar 2011 22:15
door Alex..
nice, i'm curious about how it is going to look when it's finished :D
Geplaatst: 06 mar 2011 20:57
door pomartin
update :D
i made holes for first two boosts (tomorow fine grinding)
and holes for second two boosts will be like that (quickly and approksimately drawed)
Geplaatst: 06 mar 2011 21:46
door Alex..
looks nice, how come you slovenians always seem so skilled in metal-crafting :D
Geplaatst: 07 mar 2011 08:23
door pomartin
hehe. everibody is :D
you just need some practice, and you get it throught the work you have done before ;)
Geplaatst: 07 mar 2011 19:10
door brombertje
Maybe that's why Tomos is from Slovenia :P
Geplaatst: 08 mar 2011 15:35
door pomartin
today i send cilynders, to restore
meanwhile Im waiting for parts for this project, im dealingl with this
25 kmh A35 cilinder... Im "putting" on tomos juniors portmapp.
Geplaatst: 08 mar 2011 16:03
door Fakemon
Really an interesting project, and indeed I also wonder how come you guys always have all the tools and knowledge to tune far more better than us. Haha.
Geplaatst: 08 mar 2011 16:11
door pomartin
actually... i worked for two years through all holidays, to get the money for the all equipment i need.
and knowledge comes through practice... ( I m doing this kind of stuff for around 5 years :wink: )
Thanks for comments :D
