disc(brmse)
Geplaatst: 20 sep 2008 10:38
door tomos_freak
HELLO!i see you have disc's on wich motor! and i cant understant how do you attach disc on wheel?can you show me same more detail pictures...
and how do you attach brake caliper and disc so precisely to milimeter???
Re: disc(brmse)
Geplaatst: 20 sep 2008 12:50
door PimW
On a
Tomos revival and some other newer models it's a stock part. Otherwise you'll have to machine a set of adapters on which you can mount the disks. These adapters then bolt into your old drumm brakes.
In the sales there is a topic with pictures, go look for it.
Re: disc(brmse)
Geplaatst: 20 sep 2008 14:14
door tomos_freak
aha thanks! so i can put on any disc i like?...fro scooters(over size)...?
and how do you attach brake caliper? do you weld it on motor fork?
Re: disc(brmse)
Geplaatst: 20 sep 2008 15:26
door Renault
No, you cant put any disc on it. The disc in the sales topic are from a Yamaha Aerox.
Yes you need to weld it on the motor fork.
Re: disc(brmse)
Geplaatst: 20 sep 2008 21:04
door PimW
If you use the stock tomos front-fork you would have tot stick to that size disks.
If you made or bought those aluminium adaptors you should be able to use any disk. That is if they fit and you adapt the brake caliper mounting.
If you dont use the stock parts you would have to weld a plate to the fork. (although I have seen people screw them on with special brackets)
