Worst DIY Home movie of how to remove manifold and how NOT to remove a restriction bus in the manifold. Amateurs!!You can grind a slot in it with a dremel for a flat head screwdriver.
You can pull the bus out of the manifold with some homemade tools
Heat the manifold well, or use a pipe with a ring...otherwise the manifold may break
https://www.youtube.com/watch?v=M8dkNlC ... el=Beuners
Gebruikers op dit forum: Geen geregistreerde gebruikers en 39 gasten
